Date/Time: Sun, 23 Feb 2025 02:36:17 +0000
DAX:
View Count: 556
[2021-02-10 15:07:50]
Bertram The - Posts: 3
Hi all!
Since this morning, I'm getting an error message when opening the DAX futures (DAX-2021030DTB-EUR-25):
"Download failed. Error downloading historical intraday data for DAX-202103-DTB-EUR-25. Historical data logon error: Data files folder not set for service code: eurex / Username: Bertram The"
No chart will then display.
Hopefully you guys can help me out?
Many thanks in advance for your time and effort!
Kind regards,
Bertram The
[2021-02-10 15:19:47]
Restart Sierra Chart, and make sure the symbols are set correctly for the service by using this Edit menu command:
Edit Menu: Edit >> Translate Symbols To Current Service
Let us know if this resolves the issue.
