Date/Time: Sun, 23 Feb 2025 09:01:07 +0000
Two Accounts/Differing Commissions/Trade Activity Log
View Count: 404
[2021-02-10 11:15:50] |
Luke - Posts: 142 |
Trade Activity Log: How can I set differing commissions for the same symbol if it is traded through the same trade service with two accounts (2 brokers charging different rates)?
[2021-02-10 22:35:51] |
There is no support for this. You would really just need to use another installation of Sierra Chart one for each account and each one configured to use a different commission setting in the Symbol Settings: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
