Date/Time: Sun, 23 Feb 2025 02:14:27 +0000
incorrect Large Volume Trade Indicator
View Count: 551
[2021-02-10 10:55:40]
User740709 - Posts: 153
Today, I downloaded the current version of Sierra Chart.
I have been using a Large Volume Trade Indicator study in one of my chart and it stopped working properly. It displays the marker only on the top of bars, not on the price level where it was traded as in the previous version. I checked all the setting options and there is no change and no matter what I do, it still displays incorrectly.
Could you please look at it at your side?
Thank you.
H.
[2021-02-10 14:34:36]
John - SC Support - Posts: 38116
We have made several changes to the Large Volume Trade Indicator including new options to display data for the Entire Bar.
It sounds like your setting for "Draw Mode" is set to one of the Entire bar options. You just need to change that back to whichever method you prefer to use.
Let us know what option you were using before, as it should not have changed your setting automatically. We did take that into consideration and although we may have made an error, we did test this prior to release.
[2021-02-10 15:50:35]
You are right, now works as a charm.
You are awsome.
Thanks.
