Date/Time: Sun, 23 Feb 2025 02:48:52 +0000
Horizontal Lines - cumulative delta
View Count: 493
[2021-02-10 09:41:15] |
IC2021 - Posts: 8 |
Hi there, I copied and pasted a .CHT file. Then I changed the symbol from S&P to Crude. However, the copied file didn't copy the horizontals green and red lines from the original chart (cumulative delta). How can I make sure this lines will appear in the copied version? (please see the attachment) Thanks! Alex |
[2021-02-10 13:53:54] |
Refer to this setting: Chart Settings: Show Chart Drawings For Different Symbols (Chart >> Chart Settings >> Chart Drawings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
