Date/Time: Sun, 23 Feb 2025 02:38:53 +0000
Eurex Data feed connection
View Count: 513
[2021-02-10 08:40:13] |
Antonino De Rosa - Posts: 47 |
Hello Sc Team, i don`t receive EUREX Data Feed. Run the 2226 Version. And have both Datafeed connections Activated Denali and SC All services. Could you please help. And furthermore I would like to change in this as soon as possible. Sierra Chart is going to be offering a new EUREX data feed part of the Denali Exchange Data Feed from the EUREX. The details are as follows: Need Eurex,CBOT, CME, NYMEX In the highest pacckage with MBO encluded. Thank you |
[2021-02-10 10:51:11] |
We will get this issue resolved.
[2021-02-10 11:02:25] |
Refer to: IMPORTANT NOTICE : Regarding EUREX Data Interruption for Users (SC Exchange Data Feed) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
