Date/Time: Tue, 04 Nov 2025 17:36:51 +0000
NEW EUREX DATAFEED
View Count: 908
[2021-02-10 07:07:41]
User657945 - Posts: 226
I read your comm about the realese but I need a clarificatiom you said:
If you already have the Denali data if active, nothing further you need to do. There is no exchange you need to enable at this time. Anyone using the Denali data feed will have access to the EUREX data when using the SC Data-All Services service and running version 2227 or higher.
So I'm using SC routing services, if I select SC all data services I will not more have the routing services activated since one selection exclude the other ones, can you clarify the Q please?
thx
Date Time Of Last Edit: 2021-02-10 07:08:20
[2021-02-10 07:48:40]
User282741 - Posts: 36
I'm running SC 2227 and unfortuntely EUREX data does not work with SC routing.
I can get EUREX data only with SC Data - All Services.
[2021-02-10 07:56:50]
User877753 - Posts: 152
Running SC 2227.
Package 5
Active Service: Denali Exchange Data Feed for All Services
No EUREX data.
Error message when connecting to data feed : see attached png.
image2021-02-10 08_55_02.jpg / V - Attached On 2021-02-10 07:56:36 UTC - Size: 18.58 KB - 258 views
[2021-02-10 07:56:51]
@User282741 I'm running 2226 wiht Sc routing and it works try to rollback and see if it works.
I don't know if it matters but my platform during the week is always on so I did not disconnected the feed during the night in case you have done that could be that when you tried to reconnect due to the changes in the datafeed you getting problems to reconnect may be.
Date Time Of Last Edit: 2021-02-10 07:59:24
[2021-02-10 07:58:24]
User395685 - Posts: 33
I also can get EUREX data only with SC Data - All Services with version 2227. SC routing no longer works.
However, entering a trade now automatically switches back to Simulation Mode. How should we setup live trading? My broker is AMP.
[2021-02-10 08:03:13]
I rolled back to 2226 and EUREX data still doesn't work unless I change to SC Data - All Services.
I need SC order routing to trade, so that's not an option for me.
[2021-02-10 08:04:20]
My broker is IB.
As I still have DENALI data feed, should I update to package 10 or 11 ?
Previous post :
NEW EUREX DATAFEED | Post: 250874
Running SC 2227.
Package 5
No EUREX data.
[2021-02-10 08:15:45]
Updated to package 11 : still no EUREX data.
SC 2227
Interactive Brokers.
[2021-02-10 11:03:22]
Refer to:
IMPORTANT NOTICE : Regarding EUREX Data Interruption for Users (SC Exchange Data Feed)
