Date/Time: Fri, 28 Mar 2025 11:21:16 +0000
ETH Symbol in CME?
View Count: 1071
[2021-02-10 01:30:25] |
User778613 - Posts: 1 |
Hi, I cant the find Ether (ETH) symbol under the CME section on Sierra Chart? Please advise when this symbol will be available? |
[2021-02-10 14:40:32] |
John - SC Support - Posts: 39009 |
This symbol has been added. If you are not seeing it under the CME symbol list, then go through this process to update your Symbol Settings and then look again: Global Symbol Settings: Update Symbol Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-15 08:39:30] |
Gabor Maly - Posts: 13 |
I have updated the symbol settings as per the instructions but still not finding Ether futures under the CME tab. Would the ability to see this contract require a specific data subscription? (I am on Denali including CME service pack 11). What am I doing wrong?
[2021-04-15 15:11:32] |
It looks like the symbol information for ETH when using CQG has not been entered. yet. Give us a day to get this taken care of.
[2021-04-19 19:32:21] |
John, would there be any update on this? Thanks |
[2021-04-19 19:43:57] |
We are very sorry for the delay. We'll check on when this can get done.
[2021-04-20 16:40:47] |
We will set this up today. Update: This has been done. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-20 20:24:26
[2022-11-18 03:57:29] |
User379468 - Posts: 508 |
Not seeing symbol for ETH (full, not micro) under CME, for IB-Denali after updating symbol settings.
[2022-11-18 11:41:53] |
User584084 - Posts: 268 |
The SC symbol for CME Ether full size for the Nov contract is ETHUSDRR-202211-CME-USD-50 for the IB data feed. IB Symbol is ETHUSDRR, The SC symbol for the Dec contract is ETHUSDRR-202212-CME-USD-50.
[2022-11-25 15:39:20] |
User624595 - Posts: 239 |
Typing in this symbol manually shows an error that symbol settings not found for current service. Is it OK to trade with this error? Can the settings be updated by SC for IB/Denali?
[2022-11-28 01:32:34] |
Sierra_Chart Engineering - Posts: 18974 |
We are going to set up the Symbol Settings now.
[2022-11-28 01:58:28] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
