Date/Time: Sun, 23 Feb 2025 08:44:04 +0000
accessing live us stock data
View Count: 783
[2021-02-09 19:27:04] |
Jayshwinshah - Posts: 3 |
how do users subscribe to live us stocks? I enabled my sierra data feed but that shows delayed quotes. Jayshwin |
[2021-02-09 19:37:27] |
John - SC Support - Posts: 38116 |
You need to select the exchanges for which you want the Real-Time data. In the case of the Sierra Chart Exchange Data Feed for the U.S. Stocks, you would enable the U.S. Equities exchange. You can activate the exchange on this page: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures#Exchanges Note that you also have not done the setup for the Denali Exchange Data Feed. You are paying for that data feed with the package you selected, therefore we recommend that you finish that up in order to get the Real-Time data from the CME Group. You will find the Setup Instructions here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-09 21:03:11
[2021-02-14 07:52:55] |
Gratus8 - Posts: 2 |
I am trying to subscribe to real time data for US stocks only. I've been through all the prompts yet the account does not activate. How can I activate the account to show US stocks to import volume data into the charts?
[2021-02-14 15:06:10] |
At this time we can see that you do have the Sierra Chart Exchange Data Feed active with the US Equities exchange. So you are all set. To be sure you have access, restart Sierra Chart. And follow the instructions here to open a chart: File Menu: Find Symbol (File) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
