Date/Time: Sat, 12 Sep 2026 18:17:50 +0000
Custom indicator from remote file
View Count: 716
[2021-02-09 16:30:55]
User882670 - Posts: 15
I would like to build custom study that uses data from external source (on a remote server)
For every minute it receives a single datapoint and based on that plots a line (oscilator)
I found a study "Trading Levels" - can it be used to plot a line?
Can this work with lower intervals like 15sec?
[2021-02-09 18:40:09]
John - SC Support - Posts: 47854
The Trading Levels study will not do what you want, as it is specifically looking at the Sierra Chart server to get the data.
But, you can modify the study and use what you can/need from it to build your own study. You will find the study in the RequestValuesFromServerAndDraw.cpp file in the ACS_Source directory under your main Sierra Chart installation.
Refer to the following for more information:
How to Build an Advanced Custom Study from Source Code
