Date/Time: Sun, 23 Feb 2025 08:34:34 +0000
renew the account
View Count: 527
[2021-02-09 16:05:50] |
User429467 - Posts: 3 |
hi good evening i am already confused with all your detailed information my trial period was ended i would like to renew the following : i want to see only the ES (cme) real time with market depth and also the historical data and the charts available in the sierra software I am non professional trader and i just learning it now so pls advice exactly what to do i want first to try paying it for 1 month noam ziv user 429467 |
[2021-02-09 18:08:49] |
John - SC Support - Posts: 38116 |
First, select the Sierra Chart package that you want. Since you want data from the CME, we recommend using Package 10, 11, or 12. Refer to the information here: Description of Service Packages and Pricing: Packages Follow these instructions to activate your package: Sierra Chart Purchase and License Information: Renewing Access In terms of data, you will need to use the Denali Exchange Data Feed and activate the exchange(s) you want. Follow these Setup Instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-11 08:58:45] |
hi, I can see that after the payment I did'I can see only the delayed data !!! i was sure that i will be able to see the real time data !!! what should i do in order to see the real time data in the es (futures ) ? how much it cost ? and how to do it? I am a nonprofessional trader , I have an account in Interactive brokers and I would like to have the real time data from your system without connection to Interactive brokers Pls advise thanks noam ziv |
[2021-02-11 16:03:00] |
You need to follow the Setup Instructions for the Denali Exchange Data Feed. You have done part of it by changing your package, but there is more to be done, including selecting an exchange, which will have an additional fee. There are many options available, so we cannot say exactly what your cost will be, but you can see the pricing here: Denali Exchange Data Feed: Supported Exchanges (Exchange Fees) Here is the link to the Setup Instructions for the Denali Exchange Data Feed: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* In terms of being a Non-Professional Trader, you will still need to connect to your Interactive Brokers account at least once a month to validate your Non-Professional status to the CME Group. Refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
