Date/Time: Sun, 23 Feb 2025 02:39:58 +0000
looking to buy
View Count: 432
[2021-02-09 15:50:05] |
User198876 - Posts: 2 |
Can you tell me which package is good for orderflow foot print barnumber, for US equities, Nasdaq,NYSE ect... i don't do future. thank you |
[2021-02-09 17:56:59] |
John - SC Support - Posts: 38116 |
To use Footprints (called Numbers Bars in Sierra Chart), you need to be on Package 5. You will find the differences in the packages here: Description of Service Packages and Pricing: Packages If you want data for the U.S. Equities, then you would want to use the Sierra Chart Exchange Data Feed and activate the U.S. Equities exchange. Refer to the information here: Sierra Chart Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-10 13:50:08] |
If you just require historical data, use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
