Date/Time: Sun, 23 Feb 2025 02:10:41 +0000
DOM not working
View Count: 693
[2021-02-09 15:43:57] |
Rob_2560 - Posts: 20 |
I just rearranged my charts and attached trading DOM. When I place orders, the DOM will not fill it and does not work. Please connect me so working. Thanks, Rob Slater
[2021-02-09 17:52:24] |
John - SC Support - Posts: 38116 |
We need more information. For instance: What do you mean the "...DOM will not fill it and does not work"? Are you trying to enter an order and it is not placing the order? Are you in Simulation or Live mode? Is the order being placed but not showing? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-10 13:52:58] |
Open a new trading DOM through File >> Open Trading DOM. And make sure Trade Simulation Mode is disabled: Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
