Date/Time: Sun, 23 Feb 2025 02:47:36 +0000
STUDY
View Count: 518
[2021-02-09 15:35:04]
KamilJanWlodarczyk - Posts: 7
I am looking for study of market profile which will display instead of VOLUME on "y" verticular it will display DELTA market profile on my candle stick bar.
[2021-02-09 17:36:20]
John - SC Support - Posts: 38116
We are a bit confused by the use of Market Profile and then references to volume and Delta. Therefore, we assume you are actually looking for a Volume by Price graphic.
If we understand what you are looking for then you can use either the Volume by Price study or the Numbers Bars Study. Refer to the information here:
https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID141&Name=Volume_by_Price
And here:
Numbers Bars
[2021-02-09 18:47:16]
I guess volume by price by i couldn’t find there an option like it’s on numbers by bars where it actually shows DELTA.
I wanted to have Volume by price with Delta displayed numbers and graphic. Is is possible ??
[2021-02-09 19:06:31]
There are a couple of options for how to display the Delta with the Volume by Price study.
First option, set the following:
- Volume Bar Calculation Method to either Ask Volume - Bid Volume or Diagonal Ask Volume - Bid Volume.
Second option, if you want to see the total volume bars along with the delta. Then set the following:
- Volume Bar Calculation Method: Total Volume
- Bid Volume Ask Volume Coloring Method: Difference of Bid and Ask Volume Coloring
Again, you will find all the documentation on the page here:
Volume By Price Study[/b]
Date Time Of Last Edit: 2021-02-09 19:07:00
[2021-02-09 19:13:51]
Ackin - Posts: 1865
If you want just one profile, change Input33
Date Time Of Last Edit: 2021-02-09 19:22:40
imagevbp22.png / V - Attached On 2021-02-09 19:13:06 UTC - Size: 111.29 KB - 193 views
attachmentVbP Delta.StdyCollct - Attached On 2021-02-09 19:13:37 UTC - Size: 20.7 KB - 310 views
