Date/Time: Sun, 23 Feb 2025 02:12:48 +0000
Rithmic connection
View Count: 1229
[2021-02-09 15:33:41]
User450126 - Posts: 1
I wish to use Rithmic data feed on Sierra Chart but there is service connection error: "Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe". AMP ask me to contact Sierra Chart to activate the connection. Please help. Thanks.
[2021-02-09 17:29:22]
John - SC Support - Posts: 38116
You need the Bridge Files in order to connect to Rithmic. You will find these here:
Rithmic Bridge Files
Keep in mind that we do not give technical support for Rithmic, and we recommend that you use another option (CQG or the Sierra Chart Order Routing Service).
