Date/Time: Sun, 23 Feb 2025 09:05:55 +0000
How to trade with Infinity Futures?
View Count: 1283
[2021-02-09 02:41:25]
User586975 - Posts: 1
I haven't traded for a while now, but now the software seems separate. How do I connect things back together?
Is the software no longer included?
IF not, do I have to pay for Sierracharts and Denali data feed separately, and connect it to Infinity futures for orders/routing (Infinity futures I think white labels transact) - Or can I use the feed that's supplied by my broker too?
I tried connecting to the Transact datafeed/account but it's giving a websockets error for v2226.
Any step by step guide would be super helpful, or a link to the help docs that I might've missed?
Thanks in advance!
[2021-02-09 15:26:25]
We recommend finding a different broker. We recommend using the Sierra Chart Order Routing Service:
Sierra Chart / Trading Technologies Futures Order Routing Service
At step two in the set up instructions, there are list of supported brokers and clearing firms.
Just let us know if you need further help. But we want you to have the best technical solution and using Transact is not it and we are discontinuing support for Transact.
Date Time Of Last Edit: 2021-02-09 15:27:21
[2021-02-11 16:02:01]
dem_z - Posts: 14
Hey - I'm the same user - just found my old login now.
Could you elaborate on what you mean by best technical solution? Are there any gotchas that I should be aware of (security? execution? etc)
Is order routing separate from having a broker?
I will find another broker that uses your software via your list, so thank you for that. Ideally I would like to be able to trade in-between, what's the software version that I need for it to work?
[2021-02-12 22:19:58]
The Sierra Chart order routing is completely superior in every way to using Transact. All of the benefits are documented here:
Sierra Chart / Trading Technologies Futures Order Routing Service: Introduction
No you still need to have a broker and they are listed at step 2 here:
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions
Make sure your Sierra Chart is on the current version, update instructions:
Date Time Of Last Edit: 2021-02-12 22:21:00
