Date/Time: Sun, 23 Feb 2025 02:46:23 +0000
Membership Questions
View Count: 516
[2021-02-08 22:16:44] |
UserNeil - Posts: 1 |
Hello. Going forward, if I only want to to the Sierra Level 5 (with market depth) for US Equities only (not futures), which packages do I choose? The Advanced version ($36 per month) and then up to 250 equities symbols each month? Thank you. |
[2021-02-09 17:30:15] |
You just need the Standard Sierra Chart package and then for real-time US Equities data you need to use the Sierra Chart Exchange Data Feed and activate the US Equities exchange. Instructions are here: Sierra Chart Exchange Data Feed However, market depth/level 2 data is not provided with the US equities data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
