Date/Time: Mon, 27 Jan 2025 15:16:36 +0000
Overlaying Multiple Indicators/Studies in Charts Region 1
View Count: 1096
[2021-02-08 22:05:11] |
ScottK - Posts: 43 |
Hi. I have added Volume Bars to Region 1 of my Chart. I clicked on "Draw Study Underneath Main Price Graph", and it worked fine. Now I would like to have my Number of Trades Bars overlayed on top of the Volume Bars in Region 1, yet still be drawn underneath the main price graph. Is this doable? Thanks. http://www.sierrachart.com/image.php?Image=1612821578548.png |
[2021-02-08 22:21:09] |
Ackin - Posts: 1865 |
Try: Independent (Scale Range) Chart Scale and Scale Adjusting: Independent (Scale Range) + Overlaying Studies in the Same Chart Region on a Chart Overlaying a Study on the Main Price Graph Chart Studies: Settings and Inputs Tab >> Chart Region Date Time Of Last Edit: 2021-02-08 22:50:36
[2021-02-08 22:58:43] |
John - SC Support - Posts: 37478 |
You would follow the same process as you did for your volume bars to get the Number of Trades bars displayed in Region 1. The main thing to keep in mind is that the order of the display of the Volume Bars and the Number of Trades bars is going to be based on the order in which they are in the Analysis >> Studies >> Studies to Graph window, with the item lower down being drawn last (on top) of the others. Refer to the following: Chart Studies: Study Display Order For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
