Date/Time: Sun, 23 Feb 2025 02:25:38 +0000
Order Fill Fees
View Count: 553
[2021-02-08 00:53:55] |
John Ara - Posts: 125 |
I am paying CLEARING, EXCHANGE, EXECUTION, NFA FEES to my broker (Stage 5), please help me know what is the difference between these fees and Order Fill Fees? I think I'm double paying exchange related fees. Thank you. |
[2021-02-08 12:51:50] |
The fee you are referring to is explained here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#FAQ_WhyDoYouChargePerContractForOrderRouting Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-08 14:01:35] |
'For some clearing firms/brokers, Sierra Chart has an arrangement with them for the order fill fees to be billed directly to your trading account' I copied above sentence from the link you mentioned but I'm being billed twice by both sierra and my broker. |
[2021-02-08 16:19:29] |
Who is the broker? And what fee do you see that makes you think this. This should not be the case. Can you provide a screenshot of what you see.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-08 16:19:48
[2021-02-08 17:07:57] |
My broker is Stage 5 and attached is a screen shot of fees charged to trade 15 micro Es.
[2021-02-09 01:14:14] |
Ok it is not clear to us, if they are actually billing you infrastructure transaction fees. If they are, then they need to explain why they are doing that and what specifically they are for.
