Date/Time: Sun, 23 Feb 2025 02:30:11 +0000
main window graphics setting
View Count: 428
[2021-02-07 04:37:59] |
User476002 - Posts: 28 |
hi I'm trying to find out how to change the color of the two areas I have circled in the attached image. I read the section on global graphics settings, and I have gone through that setting but haven't figured out how to adjust. I use dark mode on all my devices and these two areas are really throwing off my eyes when I switch to SC. thank you
[2021-02-07 15:28:03] |
Those have to be changed through operating system level settings. This would be considered the title bar and menu.
