Date/Time: Sun, 23 Feb 2025 02:19:18 +0000
Latest version of SC causes unknown name for custom studies
View Count: 502
[2021-02-06 19:40:52]
jwick - Posts: 142
I just upgraded to v2226 and rebuilt my studies. Now, all of them come up as "unknown name" and don't calculate on the chart. All the studies are setting sc.GraphName when sc.SetDefaults is true. If I look to add a custom study, I can see all of my custom studies with their names applied however as soon as I add them to the chart, it is listed as "unknown name" again. My code hasn't changed ... all that changed was an upgrade (unfortunately I do not remember which version I came from ... I did update within the past 30 days) and a recompilation.
EDIT: Hmm ... I tried closing and re-opening the chartbook but that didn't make a difference; however, closing and re-opening SC fixed it. Unfortunately I didn't make a copy of the log but when I quickly glanced through it, I didn't notice anything out of the ordinary so have no idea what caused this in the first place. Will report back if it reappears.
Date Time Of Last Edit: 2021-02-06 19:50:38
[2021-02-06 20:08:05]
Ackin - Posts: 1865
I have the same experience. This is already happening several versions completely randomly in combination with "Release DLL + Load DLLs".
When this happens, it is better to close Chartbook and sometimes restart the whole Sierrachart after compilation. (I personally combine it and restart after a few compilations).
[2021-02-07 09:45:44]
Can you attach the Custom Studies DLL file you are using which causes this issue. You can privately do that and we will test.
Date Time Of Last Edit: 2021-02-07 09:45:53
