Date/Time: Sat, 19 Sep 2026 12:49:49 +0000
Danali and IQ data
View Count: 931
[2021-02-06 17:23:08]
User271273 - Posts: 5
hi there sorry if confusing im trialing the package 11, advance and can see the DOM and number bars working on my futures charts whats great, but there is no DOM level 2 data for the Forex pairs, with SC services and l can see you have posted this in the past,that FX as no DOM level 2, so would l need the IQ-feed data feed for only the Forex pairs level 2 DOM so l can see the data or bars, and also can l use Denali, and IQ-feed, at the same time to run together, if this can be done on my charts danali for futures data only say and IQ-feed data specifically only for FOREX data level 2 DOM data, but can this run at the same time ?? or is there a way to get FOREX DOM data level 2 data with you or can you recommend any one ? Im in the UK,
THANKS
[2021-02-08 13:47:22]
You can get market depth data for Forex when using LMAX:
LMAX Trading Service
If IQ Feed has this, you can certainly use that data feed but you need to install another copy of Sierra Chart to use with that data feed:
Using Multiple Data and Trading Services at the Same Time
Date Time Of Last Edit: 2021-02-08 13:47:47
