Date/Time: Wed, 27 Nov 2024 02:26:09 +0000
[User Discussion] [Locked] - Setting up a permanent DOM design
View Count: 2862
[2021-02-06 11:10:11] |
User837159 - Posts: 3 |
Hello, i found the Global Settings - Chart Settings - Global option where i can design the colours of my DOM, but i can't find the place where i can permanently add all the columns i want on my DOM, i.e volume, recent bid, recent ask, stacking/pulling etc. Do i have to do this every time i open the DOM or is there a way to save it all for further use even after restarting Sierra? I am new here and all the various settings we can do on the platform is pretty overwhelming in the beginning. Thanks in advance, have a nice weekend |
[2021-02-06 18:43:50] |
user_xyz - Posts: 416 |
In the DOM you are customizing visit Trade -> Customize Chart/Trade DOM Columns. In the main SC window File -> Save All or Save your settings. Also on every exit of SC you should be prompted to Save your settings. Once you start SC back up everything should be like you left it... platform is pretty overwhelming in the beginning.
;-) Feature rich
[2021-02-08 15:21:45] |
John - SC Support - Posts: 36309 |
You need to have the Trading DOM open when you save the Chartbook. Then when you re-open it, the Trading DOM will also be opened in the same state it was in when the chartbook was closed. Refer to the information here: Chart Trading and the Chart DOM: Saving Trade DOM Configuration For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
