Date/Time: Sun, 23 Feb 2025 02:25:42 +0000
Error when trying to add a chartbook
View Count: 558
[2021-02-06 00:50:48]
User278581 - Posts: 6
Hi, just downloaded and installed sierra charts and running into a problem with downloading a chartbook. It keeps giving me an error that says, "This file does not have an app associated with it for performing this action. Please install an app or, if one is already installed, create an association in the Default Apps Settings page." I have sierra and can open it. I also checked the default apps and it's not even listed there.. know what I can do to fix it?? I'm not really familiar with sierra and tried to find this in the FAQ with no luck. Thanks in advance.
[2021-02-06 13:52:41]
ForgivingComputers.com - Posts: 1012
This was addressed here: Chartbook install issue | Post: 250444
[2021-02-08 07:55:49]
You need to open a Chartbook using the method documented here:
Chartbooks (Workspaces): To Open a Chartbook
