Date/Time: Mon, 25 Nov 2024 21:50:46 +0000
allocation acount connection, what to fill in the blanks...
View Count: 1091
[2014-02-25 04:25:33] |
User51129 - Posts: 2 |
When opening the data service settings, there are two empty boxes at the bottom and it says "Account Allocation for Orders" what would I need to put in here...?? Your help is highly appreciated. Thanks |
[2014-02-27 00:27:41] |
This feature has still not been tested and may not work properly. But we will be getting to the documentation for it as soon as possible.
[2014-03-11 04:30:34] |
We have not had time to get to this documentation yet or had time to do any further work on this feature. For the time being, consider it unavailable.
