Date/Time: Sun, 23 Feb 2025 14:51:19 +0000
EUREX EOBI
View Count: 1362
[2021-02-05 20:01:29] |
User907332 - Posts: 4 |
Hello, Now I am with trial period, and after trial I would like to access to have sierra + eurex data. Is your data service with eurex eobi is already available ? what will be the price for eurex eobi data ? Thanks in advance Best regards Kevin |
[2021-02-05 21:47:22] |
John - SC Support - Posts: 38116 |
The new EUREX EOBI data is not quite ready. It will be any day now, but there are still some technical issues that have popped up. You can follow the process at this link: New Upcoming EUREX Full Order Book Data Feed (Now Available!) We have not finalized pricing for the exchange fee yet. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-10 20:25:01] |
Hello, I am new with Sierra Chart and at the beginning all options look a bit complicated, so my question is the following : what is the package the cheapest to have EUREX EOBI real-time ? what is difference between SC Data-All Services and Denali ? I dont understand what I need to buy to have the EUREX EOBI real-time? thanks in advance Best regards Kevin |
[2021-02-11 04:51:40] |
You will need Sierra Chart Service Package 11: Description of Service Packages and Pricing Also refer to: New Upcoming EUREX Full Order Book Data Feed (Now Available!) | Post: 251083 SC Data-All Services is a service within Sierra Chart which has access to the Denali Exchange Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-12 19:49:27] |
Hello, I just bought SC and Denali for EUREX eobi, but I dont success to access to DAX real-time data. I have the following message. The symbol to open is FDAXH21-EUREX/March 2021, correct ? sorry for my basic question thanks in advance best regards Kevin |
[2021-02-17 15:42:21] |
sorry please could you answer my last message many thanks kevin |
[2021-02-17 17:18:03] |
You need to update to the latest release. You can do this following these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
