Date/Time: Mon, 25 Nov 2024 17:59:00 +0000
Message Log
View Count: 1666
[2014-02-25 03:11:12] |
User22591 - Posts: 133 |
My message log should leave my screen when I close it but it does not. What do I need to do to get it of screen?
[2014-02-25 06:57:29] |
If it keeps opening, then there is something in there that needs attention. We cannot say what that is unless we see the Message Log. You can post it by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
