Date/Time: Wed, 30 Sep 2026 08:57:27 +0000
Sierra CPU went down by 3x!!!
View Count: 1043
| [2021-02-05 14:56:07] |
| User311344 - Posts: 142 |
Dear Sierra! I dont know if thats the result of this issue in Whats_New: Corrected a minor inefficiency issue in charts when market depth data is subscribed.
but in 2226 my Sierra went down from 15%+ CPU to like stable 4-5% CPU without any change in my charts. It's incredible. Hats off to you and Thank you! Date Time Of Last Edit: 2021-02-05 14:58:35
| [2021-02-08 10:05:56] |
It is not this one that made a difference, it is the second item described underneath which is the issue because you are using the Sierra Chart order routing and we use native exchange pricing.
