Date/Time: Sun, 23 Feb 2025 02:42:14 +0000
Time zone issue on a 3rd instance
View Count: 494
[2021-02-05 14:24:31] |
User143517 - Posts: 68 |
Hi there, I have been using two instance of SC and added a third one. The first and second ones have been showing my Time zone correctly, which is UTC -03:00, after I went to Data/Trade Services Settings >> Time Zone >> Other / Custom DST and changed to the aforementioned time zone. However, the third instance seems not to be recognizing these Other / Custom DST settings. It only recognizes the preset ones. I am using SC version 2226. Could you check on this? Thanks, Joao. |
[2021-02-05 16:23:07] |
John - SC Support - Posts: 38116 |
We see that there is an issue with the new Settings Window when selecting Other for the Time Zone. We will get this fixed and let you know when it is done. In the meantime, you can set the Other Time Zone on a per chart basis. That interface has not changed yet and is still working correctly. Refer to the information here: Chart Settings: Time Zone (List) (Chart >> Chart Settings >> Session Times menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-05 19:44:46] |
We have found the issue you were having. This will be fixed in the next Pre-Release - v 2227.
