Date/Time: Sat, 22 Feb 2025 17:37:32 +0000
Eurex/Denali latency
View Count: 611
[2021-02-05 11:30:13] |
mazzy /| blast - Posts: 54 |
Does the upcoming Eurex datafeed within Denali use an access point located in Europe / Germany or in the US like SC order routing ?
[2021-02-05 12:04:40] |
Yes it comes out of Frankfurt Germany. And also if you are using the Sierra Chart Order Routing Service, use Server 3 for order routing in Germany. You do not have to use a US server. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-05 12:04:48
