Date/Time: Fri, 25 Sep 2026 05:30:44 +0000
[Programming Help] - Chart Replay Synchronisation
View Count: 726
| [2021-02-05 08:26:46] |
| User690917 - Posts: 4 |
Hey, I had already searched most of threads reagrding following problem. When i want to do a chart replay, there is always the porblem, that one of my charts in the chartbook does not playing. When i pull the "stop" bottom, then the other chart are stppoing but the one that was not playing before, is now playing. as soon as i push the play button, than then other charts play again, and the one other chart is stoping. my setting is "all charts in chartbook" - "accurate trading system backtest mode" and i also have disabled "skip empty periods" BUT i have tried the other options too. |
| [2021-02-05 14:55:23] |
| Sawtooth - Posts: 4354 |
Maybe you have started a replay from more than one chart. Or you have paused the replay, and scrolled the chart to an earlier time, and resumed with Play. It's best to always start a replay when all charts are not scrolled into the past, before scrolling the controlling chart into the past. |
