Date/Time: Sat, 22 Feb 2025 17:44:59 +0000
Doc clarification for working with CSV files
View Count: 468
[2021-02-05 06:52:18] |
User486465 - Posts: 12 |
Hey guys, please clarify the following points on working with imported CSV files (Text/CSV Data Format) - Does Sierra need CRLF or LF line separators? (I know Sierra is Windows software, so CRLF should be assumed, but my data pipeline may be Linux-based so any text files created may have LF line separators) - Does Sierra need a blank new line at the end of the CSV to signal an End of File? Thank you! Date Time Of Last Edit: 2021-02-05 06:52:32
[2021-02-05 08:18:21] |
The end of line terminator needs to be either a carriage return line feed (CRLF), or just a line feed (LF). Either one will work. There does not need to be a blank line at the end, but the final line should have a terminator at the end. Not sure what would happen if it does not. It probably would be an issue if not. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-05 08:18:30
