Date/Time: Sun, 23 Feb 2025 02:31:08 +0000
Use in Left Side Scale applied to More than 1 Study
View Count: 651
[2021-02-05 05:07:05] |
User120942 - Posts: 71 |
@Sierra Chart Engineering I have two studies with the same scaling values that I would like to display on Chart Region 1 using the Left Side Scale and still maintain the ability to adjust both studies up and down on the chart using the Left Scale. However, based on the guides for the "Independent Scale" and the "Use in Left Side Scale" settings, only one study can be controlled by the left side scale even though there are multiple studies listed as "Automatic" with the "Use in Left Side Scale" option is selected in the Scales settings. Is it possible to permit more than 1 study to be controlled by the Left Side Scale simultaneously? Thank You |
[2021-02-05 15:34:00] |
John - SC Support - Posts: 38116 |
What you are looking for is not currently supported. We will add this to our list of work, but we cannot promise when or if it will get done. There are just a lot of priorities. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-05 16:35:15] |
@John - SC Support Understood. Thanks for confirming. I appreciate you adding this to Sierra Chart's list of possible future projects. I'm hoping that this feature can be implemented in the near future as I think it will provide more flexibility and options for displaying multiple combinations of studies on a price chart that are currently not possible. Thank You |
