Date/Time: Sat, 22 Feb 2025 17:29:08 +0000
help
View Count: 403
[2021-02-05 00:54:15] |
User515176 - Posts: 1 |
Hi, I am interested in sierrachart and am completely new with it. I wanted to learn about footprint chart and the only ticker I need are spy and qqq. I am really confused with the package and the setup. Seems like the package I need is either pageckage 3 or 5 which is fine. But I am totally lost at what to do with data. I found a page talking about nonprofessional Trading accounts for $3.25 a month, is that what I need?
[2021-02-05 12:07:05] |
You definitely will need to use the Advanced Service Package 5. And for the market data, you will need to use the Sierra Chart Exchange Data Feed if you require real-time US equities data: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-05 12:07:10
