Date/Time: Sat, 22 Feb 2025 17:53:25 +0000
Eurex data not updating
View Count: 473
[2021-02-05 00:50:10] |
User652845 - Posts: 3 |
hi my eurex feed is not updating and it says that its active. can you have a look please
[2021-02-05 01:42:24] |
Make sure you are using the current symbol format. You need to translate them to that format using this Edit menu command: Edit Menu: Edit >> Translate Symbols To Current Service For example for the DAX it should be FDAXH21-EUREX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-05 01:42:39
