Date/Time: Sat, 22 Feb 2025 23:49:24 +0000
Advanced + Denali Data Feed
View Count: 619
[2021-02-05 00:46:28]
User848782 - Posts: 2
Bonjour le flux de données Denali ne marche pas il et retardée
[2021-02-05 12:16:13]
The reason you are not getting real-time data from the CME Group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees.
Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees:
If you do not have a funded trading account or one with a supported trading service, then refer to this solution:
Easy Solution to CME Funded Trading Account Requirement
We recommend using the above solution in any case to avoid this problem in the future.
