Date/Time: Sat, 22 Feb 2025 17:21:31 +0000
Change to new pricing model
View Count: 503
[2021-02-05 00:41:10] |
Marc@SC - Posts: 13 |
My current usage time ends in May. How does the transition to the new pricing model take place? Not until May or before with the remaining amount credited?
Date Time Of Last Edit: 2021-02-05 07:10:08
[2021-02-05 01:37:27] |
What we can say is there is no impact to you at all regarding pricing or services you currently have. Everything will remain the same for you.
