Date/Time: Sun, 23 Feb 2025 08:27:08 +0000
[Programming Help] - Footprint Reversal System
View Count: 1599
[2021-02-04 21:11:02]
TraderX13 - Posts: 8
I found the code for a footprint indicator on github:
https://github.com/FutTrader/footprint-system
I think the code needs to be recompiled - which I tried to do, but it failed and gave me a multitude of errors. I really don't know how to code, I just followed the instructions for compiling source code.
Can anybody who knows what they are doing have a look and see if this can be compiled for the latest version of sierra chart.
Many thanks in advance.
attachmentFootprintReversalSystem.cpp - Attached On 2021-02-04 21:10:11 UTC - Size: 165.99 KB - 488 views
attachmentFootprintReversalSystem_64.dll - Attached On 2021-02-04 21:10:36 UTC - Size: 837 KB - 382 views
[2021-02-05 00:32:08]
Flipper_2 - Posts: 57
It looks like you have downloaded the a whole heap of html code with that .cpp file. Try compiling this one. worked for me.
attachmentFootprint.cpp - Attached On 2021-02-05 00:31:54 UTC - Size: 11.39 KB - 490 views
[2021-02-05 00:43:39]
Ok - that worked like a charm. Thanks!
[2021-02-13 18:11:40]
User61576 - Posts: 445
i didn't manage to set it up although I did compile it
