Date/Time: Sun, 23 Feb 2025 02:42:18 +0000
Bands based on high/low
View Count: 733
[2021-02-04 19:37:08] |
Ben A - Posts: 123 |
Hi, Is there a study by which I can add bands to the high or low of the day with a fixed distance eg low of the day +/- 30 points and have it draw a line/band? Thank you, |
[2021-02-04 20:14:22] |
Ackin - Posts: 1865 |
Daily Range Bands Daily Range Bands or Daily OHLC Daily OHLC + the arithmetic studies: Using the Basic Arithmetic Studies |
[2021-02-05 14:59:35] |
Thanks, I have tried this and can get the bands to work but only if I put them in individually. Is there a way I can programme them to be created from one number? EG I enter 35 and it adds 35 from low and minus 35 from high automatically generated- can you please point me in the right direction for something like this? Thank you |
[2021-02-05 16:57:28] |
John - SC Support - Posts: 38116 |
Refer to the following: Bands/Envelope And also refer to the following for how to fill in the bands: Chart Studies: Filling the Area Between Two Study Subgraphs within Same Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-05 17:08:46] |
Custom Study: Daily High Low Band Library Free (2020) https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free |
[2021-02-05 18:18:22] |
Awesome! Thanks guys
