Date/Time: Sun, 23 Feb 2025 02:40:23 +0000
Volume Profile for TPO for current session only
View Count: 2287
[2021-02-04 19:12:29] |
User602965 - Posts: 3 |
Does anyone know how I can show a volume profile for the current or last TPO only and not for every TPO? I have a current 30 min volume profile aligned to far right so I can't do it that way. See screenshot. Also how can I view only the volume at price value and no histogram. Thanks! |
[2021-02-04 20:47:59] |
User68474 - Posts: 202 |
User 602965, that is a beautiful profile layout. You want to: "show a volume profile for the current or last TPO only and not for every TPO". Could you elaborate upon/describe more fully what you are trying to do? Do you mind showing your settings for how you so far have been able to: 1.) Show volume by price off to the right for what appears to be only the present period,and how that differs from what say you want to do in your query; and, 2.) What settings did you use to be able to display side-by-side current day profiles, one full and one split out? Thank you.
[2021-02-04 21:49:41] |
John - SC Support - Posts: 38116 |
@User602965 We responded to your query in the other thread that you posted in, which is here: separate volume profile for each 30 minute sub-period of classic TPO chart With respect to question Also how can I view only the volume at price value and no histogram
What exactly do you want to see? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-09 12:33:56] |
Regarding this: Also how can I view only the volume at price value and no histogram
Refer to: Volume By Price Study: Display Volume in Bars Volume By Price Study: Volume Bars Draw Method Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-09 21:27:10] |
I'm trying to only see the volume histogram for the current and previous day only (not every day in the TPO chart). Also the volume numbers get crowded and obscure the histogram. I would like to get rid of them and view the histogram only. I've attached the settings of how I did last 30 min period histogram and how I split profiles using "Letter/Blocks in Own Column and Standard Profile".
