Date/Time: Sun, 23 Feb 2025 02:47:40 +0000
cumulative pulling stacking
View Count: 825
[2021-02-04 19:11:03] |
MarcOh - Posts: 168 |
Hey guys, why does this function disappear after a certain amount of time? Dont get it... Thx in advance. Marco |
[2021-02-05 12:30:36] |
It may have gone offscreen based on the number of market depth levels.
[2021-02-05 16:16:02] |
Good advice. I will check this. So.. what is the minimum of depth level to show the sum? Is there are minimum? have a relaxing weekend. |
[2021-02-05 17:17:57] |
John - SC Support - Posts: 38116 |
There is no minimum. You can set the number of depth levels to be displayed with this setting: Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
