Date/Time: Sun, 23 Feb 2025 08:29:27 +0000
Spreadsheet programming question - GetCorrespondingMatch
View Count: 552
[2021-02-04 17:18:40] |
User183724 - Posts: 191 |
Need an example of GetCorrespondingMatch if anyone has one. thx tim
[2021-02-05 11:18:18] |
We do not have an example but the function is documented here: https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#GetCorrespondingMatch_Function Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-05 13:34:28] |
this is something sc wrote in house and you cant provide an example of how its used? incomprehensible...
[2021-02-13 07:06:41] |
We just do not have an example put together. That is all. We can work on one when we get to it. We are working on improving the documentation and putting together example values now. There is an example here: https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#GetCorrespondingMatch_Function and a sample spreadsheet attached. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-13 07:25:33
