Date/Time: Sat, 22 Feb 2025 17:19:08 +0000
flux et marché
View Count: 1009
[2021-02-04 17:03:00] |
User868441 - Posts: 2 |
je n'arrive pas a activer le Flux de données d’échange Denali et choisir les marchés, pouvez vous m'aider svp, j'ai injecter 50 dollars par erreur en faisant les manipulations. Cordialement Thierry Sinhnachack |
[2021-02-04 17:51:01] |
John - SC Support - Posts: 38116 |
From Google Translate: I cannot activate the Denali Exchange Data Feed and choose the markets, can you help me please, I injected $ 50 by mistake while doing the manipulations.
First, we want to point out that you just activated the Sierra Chart Exchange Data Feed and the EUREX exchange within it. If you want to get the Real-Time EUREX data, then this is all appropriate. If you do not want to get the Real-Time EUREX data, then you will need to cancel the exchange and cancel the Sierra Chart Exchange Data Feed. Second, if you are wanting data from the CME Group, then you will need the Denali Exchange Data Feed. We are working on the Setup Instructions for the Denali Exchange Data Feed to reflect the changes in our packages. The main change is that you would want to change your Service Package from Package 5 to Package 11 instead of activating the Denali Exchange Data Feed itself. You will find the Setup Instructions here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
