Date/Time: Sat, 22 Feb 2025 17:31:05 +0000
Things not working after update to 2226
View Count: 462
[2021-02-04 15:07:56]
User158665 - Posts: 44
After update to 2226 many things are not working anymore, Period-OHLC is calculating each renko, and not RTH session (as used to work in version 2193)
I changed nothing, only updated and now my flex renko charts are showing time 00h. I have to keep reloding data for the right time to work, because of this I cant use any tool like Projection or Retrace or other drawing tools.
In the picture you will see that time is showing 00h, VWAP is not working because of this.
After going to 2226 I tried 2220 but it is the same for me.
The last working version for me is 2193.
imageChart Not Working.png / V - Attached On 2021-02-04 15:04:03 UTC - Size: 127.48 KB - 197 views
imageChart Not Working 2.png / V - Attached On 2021-02-04 15:04:07 UTC - Size: 102.13 KB - 205 views
[2021-02-04 15:34:46]
John - SC Support - Posts: 38116
You have a custom study that is causing these problems. Refer to the information here:
*IMPORTANT* Notice: Custom Study Improperly Altering Time Scale of Chart
