Date/Time: Sat, 22 Feb 2025 17:23:10 +0000
dax incrementation with sierracharts
View Count: 538
[2021-02-04 13:39:14]
User470468 - Posts: 1
hello, would anyone know why i have the wrong incrementatioon on the future dax?
i have no data in 0.5 with iqfeed
http://www.sierrachart.com/image.php?Image=161244622532.png
Date Time Of Last Edit: 2021-02-04 13:44:13
image1.PNG / V - Attached On 2021-02-04 13:39:46 UTC - Size: 164.05 KB - 185 views
[2021-02-04 14:14:39]
User657945 - Posts: 226
The Eurex has changed the Dax tick size and there are no more .5 ticks since december 21
https://www.eurex.com/ex-en/find/circulars/circular-2069732
[2021-02-05 11:11:31]
You need to update the chart Tick size using this setting:
Chart Settings: Tick Size (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
