Date/Time: Sat, 22 Feb 2025 18:33:07 +0000
reset NPL
View Count: 468
[2021-02-04 11:56:58] |
IC2021 - Posts: 8 |
Hi there, I'm testing many different strategies during the day. is there any function to reset my NPL? - so I can compare the strategies thanks |
[2021-02-04 13:22:18] |
Yes you can change this setting to the current Date-Time when you want to reset it: Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
