Date/Time: Tue, 29 Sep 2026 13:37:43 +0000
Is TT REST API usable with a SierraChart Order Routing service subscription?
View Count: 808
[2021-02-03 21:18:36]
uM8137 - Posts: 183
Greetigns!
background to my question:
a) I use SierraChart (advanced 5 package) for API access to automate strategies and recording data.
b) For manual scalping, I find the user interface to Jigsaw to be much better.
Therefore I would like to use both. My question has to do if this is possible with the SierraChart Order Routing service based on TT.
c) I see that Jigsaw provides a TT REST API based connection handler that requires an ApplicationKey and an ApplicationSecret.
d) When one subscribes to the SierraChart Order Routing Service that uses TradingTechnologies (TT) as the underlying order routing service, one has then an active TT account, I believe.
So my question:
If I have, (e.g. with AMP Futures), a SierraChart Order Routing Service subscription, can I also get the TT REST API?
i.e. an Application Key and Application Secret that will allow me to use Jigsaw at the same time as I have my SierraChart running?
Thank you.
