Date/Time: Sat, 22 Feb 2025 18:10:36 +0000
Discrepency with Trading DOM's DPL versus Chart Inset DPL per attached Print Screen
View Count: 485
[2021-02-03 19:31:35] |
User388297 - Posts: 8 |
Hello Support, Thanks for your help and patience here. I'm writing about two issues that I couldn't seem to resolve on searching the Documentation/Table of Contents or the Support Board. Briefly: 1) In the attached print screen, why do the two DPL's have two different values? 2) On opening SC, sometimes one DOM table is opens (#8) and sometimes two DOM tables open (#8, #10). How do I keep it to a single DOM? I have just moved from TransAct to AMP both in Sierra Charts and find there are odd differences like the above despite using the same installation (copied Transact subfolders to Sierra Chart subfolders, version 2222 64bit (35810)). On the attached print screen, the DOM "table" on the left shows a DPL of 0.00P, yet the blue "insert" in the price chart's upper left corner reports a DPL of 3.25P. I believe this has been a problem in real trading with the AMP vs. TA setup even though the files should be the sameā¦ Thanks again, User AC... |
Private File |
[2021-02-04 14:08:48] |
Refer to this page: Help With Daily Profit/Loss Value 2) On opening SC, sometimes one DOM table is opens (#8) and sometimes two DOM tables open (#8, #10). How do I keep it to a single DOM? Window, CB and CW Menus And do what you want with them. Also you should be using the Sierra Chart Order Routing Service instead of CQG: Sierra Chart / Trading Technologies Futures Order Routing Service It is much better. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-04 14:12:21
