Date/Time: Sat, 22 Feb 2025 18:08:27 +0000
can I edit this readout/toolbar/don't know the name, on my Sierra Chart
View Count: 433
[2021-02-03 17:46:45] |
User708302 - Posts: 6 |
Hi. Please see the attached image - I'm looking for the name of this readout/toolbar on Sierra Chart, and I'd like to know if I can edit it. It's likely in charting graphics settings but I don't know what I'm looking for. I'd like to delete some info in the middle (H: L: O: etc) so I can see the info all the way at the end which is cut off due to space. Thank you!
[2021-02-03 18:26:21] |
John - SC Support - Posts: 38116 |
That is the Chart Header Line and it is very customizable. Refer to the information here: Global Settings Menu: Customize Chart Header - Standard (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
