Date/Time: Tue, 29 Sep 2026 19:44:25 +0000
Buy/Sell buttons on Control Bar
View Count: 1739
[2021-02-03 16:23:24]
User203781 - Posts: 55
I used the customization facility to add Buy, Sell, Flatten, and Cancel buttons to the control bar. They look pretty but don't actually do anything. What am I missing?
Thanks.
[2021-02-03 17:43:39]
John - SC Support - Posts: 48059
If they are not functioning, then you should be getting a notice in your Message Log telling you the issue. In particular, you need to be on a chart that has Chart Trade Mode On and you need to have the option for Trade >> Trading Keyboard Shortcuts Enabled.
Refer to the following:
Trade Menu: Chart Trade Mode On (Trade menu)
And the following:
Trade Menu: Trading Keyboard Shortcuts Enabled (Trade menu)
[2021-03-24 15:06:13]
Per its custom, the latest Windows update bombed my setup. Reconstructed SC as I want it. The control bar now has large buttons for BUY, SELL, FLATTEN, CANCEL ALL, and STOP TO BE. Four of them work. FLATTEN does not. Any ideas? Thanks.
[2021-03-24 15:18:21]
Tell us exactly what option you selected for the Flatten option that you added to the Control Bar.
[2021-03-24 15:43:14]
Trade Flatten All Positions
[2021-03-24 16:36:08]
That option does not work in Simulation mode. Are you using it for Live trades or Simulation?
Date Time Of Last Edit: 2021-03-24 16:43:22
[2021-03-24 16:44:08]
Last post has been updated.
[2021-03-24 18:59:34]
Sim. Switched to TFO. Thanks.
