Date/Time: Sat, 22 Feb 2025 18:20:48 +0000
Amp futures account + stock data?
View Count: 925
[2021-02-03 14:05:27]
User559224 - Posts: 22
Can I have both SC futures trading and stock data at the same time? I know my account through Amp would be a denali data feed but I need to be able to trade futures while also use SC for charting stocks real-time.
[2021-02-03 15:04:18]
John - SC Support - Posts: 38116
Yes, you can have both data at the same time. As you state, you use the Denali Exchange Data Feed for the Futures data. The stock data is available through the Sierra Chart Exchange Data Feed. You would need to enable the data feed and activate the U.S. Equities exchange. You will find all the information on this page, including the Setup Instructions:
Just be aware that you cannot have the Sierra Chart Exchange Data Feed paid through your AMP account. Therefore, you would need to pay for it by adding funds to your account.
[2021-02-03 15:45:23]
Thank you but what feed would I need to select in order to have both SC Denali TT + equities while also being able to trade from the futures feed?
[2021-02-03 16:11:41]
You need to use the Sierra Chart Exchange Data Feed for the stock data. It is seamless in terms of using both the Sierra Chart Exchange Data Feed with the Denali Exchange Data Feed as they are serving different data.
Follow the Setup Instructions here to enable the Sierra Chart Exchange Data Feed and activate the U.S. Equities exchange:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions
